All,
I have searched for as many references to sierra%stalks%wiring and i have found lots of useful info, but most threads stopped before a solution :-(
does anyone have a good diagram / description of how to wire the sierra stalks ( ground switching - no horn button and a round hazzard switch ) to the
rappidfit loom - which i think is very simular to the premier wiring loom.
I have a positive switched relay pack too by the way.
many thanks,,
ian.
Dont know if this will help but attached anyway.
If you dont find what you are looking for I should have some diagrams for you tommorow.
Are they BG83 stalks - numbers on them somewhere.
Paul
wicked cheers for the help.
we got it sorted in the end with a haynes diagram...
if it makes it easier for everyone else i might make a diagram too and post it up here.
yes please diagram would help me as i be wiring mine up pretty soon. think mine are later ones so im gonna need relays.
rob
okydoky, ill sort one out on tuesday for you.
