I need an amplifier for my car and the local factor has suggested 3 different possibilities - can anyone help with a definitive answer?
2litre pinto, electronic ingnition and twin 40 webbers.
Part number or model would be very helpful.
Gary
Pioneer do a kick ass 500 watt per channel phat ice jobbie....
I presume you don't have one at all then?? To take a referance or part number from??
Perhaps you could trace the dizzy part number to get a model & year it was originally from.
What dizzy do you have? Inductive or hall effect?
Not sure - how do I tell the difference?
G
2 wire plug as part of dizzy body is hall effect - plug on end of lead with 3 connections is inductive. Odds on its the inductive.
The amp for inductive has the plug at 90deg to heatsink. Hall effect has plug on the end. Try a search and you will find some pics, wiring diags etc.
My for sale ad has pic of inductive dizzy and amp.
See this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=18515&page=&contribmessage=none
Look at the 5th post down.
Amplifier 'A' is the one you want. It's Motorcraft badged IIRC.
HTH,
James
