Oh dear.
edspurrier - 6/8/07 at 05:19 PM
Just to share frustration. All the under-dash wiring now done, neat, and tidy.
Just discovered the main loom power terminal tab on my Sierra ignition switch has fallen off. There's nothing left on the switch to fix it back to. Must have pulled it a bit.
Ah well. Fortunately have a spare column, but not sure that bit can be pulled in and out....
PeterW - 6/8/07 at 05:51 PM
Switch can be removed fairly easily
I've got a spare one lying around with all its plugs etc on it if you want it
Pete
edspurrier - 6/8/07 at 06:17 PM
Thanks - I've got a spare colum so I'll use that switch, but will let you know if that one's broken
robertst - 6/8/07 at 06:27 PM
cant you solder the terminal back on?
[Edited on 6/8/07 by robertst]
edspurrier - 6/8/07 at 06:32 PM
Only a tiny nubbin left, I;m sure it would fall off again.
