Hi I've been trying to sort out the wiring from my donor car (1970 Escort GT) and I have a problem with the start switch wiring.
I think that the wiring should be something like this:
[img]/upload/start_switch_2.JPG[/img]
My problem is that the ignition/starter switch connector is grounded. So if I tried to start the car there would be short circuit. Does this mean that
the start switch is damaged, or I’m missing something?
i cant rember exactly how mine was wired as its a different style Lucas item, but you will need a possitive and a negative connection across the switch terminals as it energises the relay to switch the main starter wiring, ive got a spare starter relay if you need it?
Hi!
I will try to switch it outside the car...
Thanks!
Problem Solved!
The multimeter was giving a bad reading. Change the battery and everything was ok!
