Hi, I have spent all weekend wiring in the ECU for my MK with 2.0L Pinto with Carbs and have now connected everything , but I notice on the Vikki
Green loom there are 2 wires one white and one white/black that the wiring diagram states are the important wires for wiring up various ignition
systems.
What do I do with these wires..
John
These wires should connect to your coil.
When you say ECU do you mean the ignition amplifier (Black plastic box mounted on an alloy plate with a 7 pin plug at the bottom and Motorcraft
moulded on the side)?
If so and IIRC 2 of the wired from the ignition amp need to be spliced into the wires you refer to to drive the coil.
HTH
NO, it's the ECU that is about 5" square and 1" thick with a 24 way connector which goes to a stepper motor on the carb, a 3 pin plug
to distributor, 3 relays, and the coil + suppressors
John
Can't help with that one I'm afraid.
I had the same st-up on my donor car but after looking at the installation I ditched it in favour of the earlier inductive discharge set-up with the
ignition amplifier, 2 wire dizzy and DGV carb.
