I have no temp sensor/switch in my rad so has anyone used on of these? Where did you get it from and what price did you pay?
[Edited on 30/8/07 by matt.c]
Housing was £15 from CBS - Sender came with water gauge and switch came with fan - Should do it for under £40 if
you search around...
CBS also do a fan switch which is just a thermocouple that you feed through one of the joints using a bit of neoprene seal
[Edited on 30/8/2007 by NeilP]
I've used one made by Koso. I got it from PM Tuning, it was only £8
I bought the one pictured for £30 ish, wish Id looked around could have made it cheaper doh!
works great tho. got a SPAL 11" fan was around £50 and the two seem to work well.
The switch I got was 95 on 85 off tho so I ended up buying another switch for 88 on.
