Hi all,
Im about to sort out all the wires behind the dash and i dont have a wiring diagram. Its a luego loom with relay pack. Is there a diagram
available?
Thanks kenton
Kenton, There was never a diagram as such just some (dubious) written instructions - I'll see if I can dig out and scan in - In the meantime you should have everything on the loom labelled as supplied so you should be able to lay out over the chassis and do trial fit etc?...
Thanks,
yes it was labled, the rest of the loom is done its only the connections behind the dash.
I was hoping not to have to go through them with a meter!
kenton
