LED Lights and Flasher Unit
simonk - 29/9/07 at 04:46 PM
Hello all
Car largely wired now, which is good news, but the indicators flash too fast. From reading I think that this is due to having LED rear indicators and hence not enough load. With hazards on all works OK so I guess there's enough load with everything flashing.
I've heard that this can be cured by adding a resistor - but I have no idea where in the circuit and what value.
Any advice gratefully received - I have conventional front and repeater units, with LED rears.
Simon
Agriv8 - 29/9/07 at 05:07 PM
You can simon ( I have no idea how though ) , The way I did it was a special digital relay from ebay that does not care what the load is for its flash rate .
regards
Agriv8
nitram38 - 29/9/07 at 05:29 PM
The led (one here) relay is the best option as resistors tend to get hot.
There is a down side to using a relay of this type in that if a bulb is not working on the old hot wire type relay, the fast flashing lets you know that your indicators are faulty.
This can be handy if you are about to turn with a steaming great lorry behind, bearing down on you!
[Edited on 29/9/2007 by nitram38]
RazMan - 29/9/07 at 05:34 PM
Please please do not use a resistor - its such a bodge and they can actually be a fire risk
simonk - 29/9/07 at 06:06 PM
Thanks all, will go for the correct relay.
Simon
martin1973 - 29/9/07 at 09:14 PM
i have a relay here for leds,
brand new fiver inc post if you want it.
martin.m3mje@btinternet.com
