Hi, I've been offered a reconditioned alternator from a diahatsu charade (Lucas item LRA543) for £25.00.
I note it only has two mounting points, how have others set about mounting these on a Pinto?
I used a similar model from a Dryhatshoe van.
My method, for what it's worth...
Bottom lug goes directly (with a spacer) onto the engine lug that originally secured the tensioner bar and the tensioner bar is modded to affix to an
extended exhaust manifold pin.
Works for me..see below
Scuze the dust...I was sanding some shelves nearby on Sunday and I haven't made the bonnet yet.....Bloody DIY !
[Edited on 22/9/03 by jonti]
Does the heat from the exhaust affect the wiring at all? My clutch cable was not as close to my exhaust and that melted.
yours, Pete.
yours, Pete.
Nice one Jonti, this picture paints more than a thousand words.
I was concerned that the alternator might be subject to a rotation force with the force of the pulley and only 2 mounting holes. Yours seems solid
enough does it?
Your picture also helps me to visualise the problem I'm going to have getting the bottom radiator hose sorted. Looking from the front I have to
get to the bottom RH corner of the rad and so the fan belt is going to come in to play.
BTW, what fan belt did you use?
Glad to be of help....Its plenty solid enough.
Measured up wiv a bit of string once all the bits were in place then toddled down to Halfords and got one that length. Did you know the part number on a fan belt often indicates it's length in mm ? Nota lota people know that.......mind you I bet SG did.
PS you'll have to frig about with the heater hose fitting on the WP too.
