Dashboard wiring was changed to use a single connector.
before:
wiring before
after:
after
Notice the self adhesive insulation strip behind the fuse box contacts - prevents any possible contact of expose live terminals (yes, they should be
shrouded type) and body work.
Now that could explain why lights aren't working properly
is that a flasher relay you got next to the fusebox or is it a high-beam relay?
it is high beam - I notice it is mounted opposite way to how it was before - surely that is not what can be causing my lighting probs????!?!?!?!?!?!????????
