Hi,
I initially wired up my lights using the additional relay set-up but only managed to get the lights to work when I pulled the light leaver back, ie in
flash mode.
Eventually I grew frustrated and removed the relays and wired the light switch directly to the loom without the additional relays. Now the main and
dipped beam work perfectly but the flasher will not.
Any ideas on this?
Do I need to have a flasher option or will side / dipped / main be enough for SVA & MOT?
The relay will prevent the high current burning out your light switch! Don't switch anything on!
First get the relays to activate via the light switch (one relay for high/low beams) Then apply a 10A switched feed to each relay, then connect the
headlights to the other side of the relays.
RM - you said I should use relays for my dipped beam lamps (re: my lighting problem) and whilst I wholeheartedly aggree, I looked in mk2 escort manual
and see no relays for any lights. Only relay spotted was for the horn.
not meant as a critisicms, just an haynes manual observation.
Ahh I am not sure about the Escort switchgear and was basing my suggestions on the Sierra jobbies which definitely needs relays or you'll let the
smoke out of the switches
TBH I would use relays in any case - it makes for a slimmer loom to the switches.
There are errors in the Vicky Green wiring diagram around the column switches, have a search for details. If you are using Escort switchgear you
probably don't need the relays.
Geoff
You've gotta use a relay with the Sierra column - the wires are tiny! I have used relays for all lighting (including a relay for the fog light). I am not using one for the horn, as I am using a low current bike horn. I just hope the Sierra column wiring is up to the job!
The ones in my donor had brass ring to brass contacts but I didn't use it. I found a Fiesta Mk2 used the same wiring but with indicator stalk mounted horn push so I used the switchgear from that.
