I'm after some cheap black bodied lights as I won't really be using them but I don't want them so cheap that they'll fail on beam pattern or owt and I'd like the kinda dome standard body rather than the double domed cheaper shaped things that I've seen. Any ideas as I'm a bit confused over H1 and H4 bulbs and all that.
Premier Wiring do a set of 5 3/4 's in black for £25 the pair!
Not nice, but SVA compatible.
http://www.premierwiring.co.uk/index.php?module=Website&action=Text&content=1133393686882-8823&parentContent=1133392767901-3830
wow that is cheap
A bit cheapio looking though? (That probably is because they are cheap though admittedly)
Watch out for sharp edged lens clamp on the base - less that 2.5 mm rad.
Yup have to agree with steve, my 1st set of cheap £25 lights failed SVA on beam pattern and edges, i wouldnt go for the cheap lights again infact the price i paid for the black on brass 5 3/4"s from SVC was less than some of the other crap out there, plus i ordered after my SVA fail and they arrived the next day
