Different edis modules.
Danozeman - 5/11/07 at 09:39 PM
Is there actually a difference between edis 3, 4 etc??
Just wondering as i have a couple of different ones sitting here.
chasmon - 5/11/07 at 09:42 PM
EDIS3 - I don't believe this exists.... :p
EDIS4 refers to the 4 cylinder version 6 to the 6 cylinder version and 8 to the.... You get the idea...
MikeRJ - 5/11/07 at 11:22 PM
All the EDIS modules are visually similar. They all use the same housing and connector is almost the same on the 4,6 and 8 cylinder versions apart
from being keyed differently to prevent the modules being interchanged.
http://www.megamanual.com/ms2/EDIS.htm
The Ford ESC module look very simmilar to the EDIS, but they have a red plastic panel on the front (with "ESC" embossed into it) and they
have a vacuum connection.
