Anyone know the cheapest place to get a decent fuel pressure sensor 1/8 npt and Oil temp sensor although not sure of the thread yet!
Dave B
Here ??
I'm looking at getting some so had that page open!
Thanks!
Dave B
senders will be specific to the gauges tho wont they?
ie Ive autometer gauges and need autometer senders.
I have a race technology LCD dash and will need analog sensors I think!
Dave
I have a Race Technology data logger and dash and was going to use the same senders, provided they are supplied with a calibration sheet, i.e. what
resistance at what temperature / pressure!
Wyn
let me know how you get on if you would...I have to conect the sensors direct to the dash and the analog inputs to the dash mean that 5-12 v needs to be supplied to the sensor from a source and then the sensor will vary the input to the sensor channel on the dash. For a std temp sensor with a single pin this will be a problem I think!
Dave
I have a simlar difficulty!
THe Race Technology Forum is very good - I was going to post a question on there today.
Regards
Wyn
Dave
I've just ordered two VDO pressure sensors (oil and fuel pressure) and an oil temperature sender from ETB. They'll provide the data for them
as well so they shouldn't be too hard to set up!
There are some useful topics on the Race Technology Forum -
5 volt feed to sensors
VDO sensors and data figures
And on here -
How to wire the sensors
I hope this all helps!
I'll keep you updated - hoping to get them wired in over the weekend although I don't have my logger / dash or ECU as they are all still
with Emerald.
Regards
Wyn
