Hi all,
I have to fit a second fuel pump with a swirl pot I have fitted, the advice seems to be to run a new positive wire rather than run it from the first
pumps connections,
can I run a wire direct from the battery, with its own switch?
will that cause any problems- battery discharging etc?
les
Agreed, it would make more sense to common the pumps together and run them from one fuse - easy to fault find too.
thanks guys,
sounds like the answer
les
