I've been meaning to ask this for a while and somebodys just mentioned it in the charging battery thread.
I'm after a small female socket thats water/weather proof where there is nothing in it.. or has a suitable bung to prevent water getting in.
Its for trickle charging the tin-top which doesn't get used that often, I intend on mounting it on either the face or the underside of the
sideskirt where I suppose it would be quite exposed.
There's lots of connectors available that are weather/wayer proof when there connected together, but not many where the female socket left behind
is still safe.
I've had a look in RS's catalogue and asked in some industrial suppliers but was drawing a blank or looking in the wrong place so I thouht
i'd ask you good people
I fitted something similar to my caravan when I had it. Check out caravans accessory shops. Just a thought, do you have a tow bar with twin seven pin sockets? The accessory socket may be wired direct to the battery?
I've already got a lead from the battery down to the sideskirt with an inline fuse as the car has no door or boot locks so its a way to get power
into the battery in an Emergency.
I was just after a small socket to permenantly mount to the underside or skirt somewhere, it would only have to take about 1amp max from the
Maintanance charger I would have thought.
I know the connection isn;t right, but this idea?
http://cgi.ebay.co.uk/OPTIMATE-THREE-SP-SPARE-WATERPROOF-LEAD_W0QQitemZ250236094739QQihZ015QQcategoryZ25643QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I got one of these for that job
LINKY
Regards
Rich
Hmm not exactly sure what the optimate lead is on Ebay but i'll keep and eye out for it.
I've looked at a few lighter socket type designs but not sure how weatherproof they'd be.
I was looking for something really small like a RC car power plug but again there not waterproof when you take the malke bit out... I suppose its only
12V tho so it doesn't have to be super water tight.
what connector do kenlowe engine warmers use?
I am sure there is something in RS, just a matter of finding it.
Ok this is a US site, but I found one in a yacht chandlers in Lymington
Linky
"I am sure there is something in RS, just a matter of finding it."
You might well be right.. I would have thought there'd be something out there, just from a application i've just not thought of.
Most of the connections I have found have been a bit on the big side or expencive as there quite high power rated.
Maybe something like a USB plug with a rubber bung in it or an audio connector or some kind. Might have to try search the IP rating of whats
splashproof waterproof etc
