bec non start
iceman26 - 31/5/08 at 10:56 PM
hi i have a fazer 1000 same as r1 on carbs have wired up but it will not start
i think it is fault with starter relay cut off
i have by passed clutch and side stand and the kill switch
but when i join the to black wires together to close off the cut of relay nothing happens
if you earth the starter relay with the 4 pin plug and the battery and to motor connection it will turn over
do you think this is a fault with the cut off relay and could i just fit a 2nd relay instead of having to get a new one
the relay in question is this one
thanksImage deleted by owner
adithorp - 31/5/08 at 11:12 PM
Have you by-passed the clutch, side-stand and neutral (or is it in neutral) switches?
adrian
iceman26 - 31/5/08 at 11:23 PM
have done clutch and side stand do you have to do any thing with the neutral switch
mark
iiyama - 1/6/08 at 06:12 AM
Check the gearbox is in neutral and try again
tim windmill - 1/6/08 at 06:50 AM
have you checked the tilt switch?
smart51 - 1/6/08 at 07:29 AM
Make sure it is in neutral. Put the handbrake on. Short the blue + white wire from the starter relay to ground for a couple of seconds. The starter motor should turn. If it does, your shorting of the clutch switch etc is the problem.
iceman26 - 1/6/08 at 01:54 PM
i have just checked the neutral switch and it is doing nothing witch way should it switch when in neutral should i get a earth or +
thanks mark
adithorp - 1/6/08 at 02:27 PM
When in neutral it goes to earth. Short the wire to earth and see if it starts.
adrian
iceman26 - 1/6/08 at 02:29 PM
have done that still nothing any more thoughts are very welcome
