how can you test whether or not the vr sensor is giving off a pulse?
wave a screwdriver over the end,you should get 0.5 volts ac
Plug the input into a cheap amp and spin whatever you're testing up.
As long as you're getting more than 20 pulses per second you should hear something..... Interference might be an issue though....
Everything you ever wanted to know about megasquirt is here
Although it can be hard work finding the answers
measure the resistance if isn't there it wont work..
yupsz an AC voltage swing should be visible...
don't untherestimate the voltage...it really can go high...
Tks
