Each of my dash clocks need an ignition feed. How have people wired it ?
Seperate wire for each clock, or daisy chain them together?
You could do either, can't see it makes much difference, they are all low power devices,whichevers easier.
I suppose if you daisychained them and the developed a fault it would be easy to diagnose locally by what did/didn't work?
