I originally messed around with my Megajolt with a desktop pc next to teh car in the garage.
Now I'm on the road I want to use my laptop but the Megajolt software wont start up. When I click the icon I get the start banner then this
message:
mjljconfig.exe has encountered a problem and needs to close. We are are sorry for the inconvenience.
Any software guru's know whats causing the problem? Registry setting possibly?
Have you tried re-installing the software?
Also, does your laptop have enough memory (not usually an issue) and disk space left to run the code?
If that doesn't work, I recommend posting this question on the Autosport Labs forum - Brent Picasso is always ready to help out...
HTH,
That sounds like a general FUBAR fault.
It's going to be tricky sorting that one out because it's so non-specific...
Try uninstalling the software and do a fresh install....
