Anyone using a 8 way fuse box where the wires enter underneath?
The reason is that i checked my preinsulated terminals fitted, but the covering does not allow terminals on.
So do i use non insulated one's and cover in heat shrink?
Hi
That's what I used.
Bit of a pain if using insulated crimps.
I think these types fit.
see Polevolt's
part number 30-292-1 ,2,3
on page 15
don't forget they use a different crimp tool.
Oh good.
Well will see, about those, normaly got some knocking about from the aftermarket switches or lights.
Yep - the above will fit. The "hard" plastic ones work a treat
Available from VWP, RS etc.
yep, i used the hard plastic ones on my 8 way fuse box.
stuart
Premier Wiring, have a box of hard plastic ones, terminals and crimpers for this type of terminal.
Question: Why cant i use the reinsulated crimpers or pliers??
