Well I have spent the last couple of days crimping and soldering but there seems to be another year of wires to terminate. Anyway I am about to wire
the injectors and the coil pack and just want to confirm which is cylinder 1 (front or rear now that the engine is in line) and which pin is which on
the coil connector? Any info would be greatly received.
thanks
Dave B
Cylinder 1 is at the cambelt end and four at the gearbox end.
Front cylinder is number 1 - not too sure about the coil connections , I have a feeling the center pin is the 12V `in` ?
Dusty Thanks!
Dave B
the coils pack has the cylinder numbers on already if that helps u
