hi all, i have out all my indactors on know and they flasher to quick then they slow down and then get quicker, and carry on going doing that, is it
my realy it came out of the sierra, should i get a new one? or have i got a different promblem?
thanks
stuart
Have you connected up all of the indicators using standard bulbs in each or used LED's?? Sounds strange being variable though
standard bulbs. does any body know what the total watts was the sierra indactors where?
stuart
indicator bulbs are typically 21 W.
to work out total wattage multiply 21 by the number of bulbs.
this does not ofcurse include any side repeateer lamps not the lamp in the dash board.
i have worked out that i have taken 11w per side off the orginal wattage, would that make it do that? as well if i get a new flasher unit would it
work ok for the sva? or do i need to put a few lights under the bonnet to slow it down?
thanks
stuart
I can recomend this:
http://cgi.ebay.co.uk/3-Pin-Electronic-LED-Flasher-Blinker-Flash-Signal-Fix_W0QQitemZ280247710688QQihZ018QQcategoryZ72233QQtcZphotoQQcmdZViewItemQQ_tr
ksidZp1713.m153.l1262
It runs on any combination of LED and conventional bulbs upto 20A, it took about a week to come and has a tiny delay when indicating, other than that
can't fault it!
Originally posted by Stuart_B
i have worked out that i have taken 11w per side off the orginal wattage, would that make it do that? as well if i get a new flasher unit would it work ok for the sva? or do i need to put a few lights under the bonnet to slow it down?
stuart
