Hi all, has anyone used a dash mount modified or not that they can recommend ?
Before I buy a 5-10£ one off fleabay and find it falls out !
Ive got a charger one that sitsin the cig lighter.. its pretty good and U can play ur songs thru radio with no wires...also calls come thru ur
speakers
like this
FM TRANSMITTER HANDS FREE CAR KIT CHARGER HOLDER for IPHONE 5, 4, 3GS, 3 & IPOD | eBay
Should Of said its for trackday use only really and so I can use Harry lap timer and video recorder.
I have always used the Brodit range. Top quality and rock steady. I use
the BB one but my misses has the i-phone 3 version in her Landy and it is flocked so to not scratch
I have a Brodit one on my dash for the iPhone 4 also have a spare wired one with cig plug surplus if your interested.
The Brodit ones are top notch (reflected in the price) my spare one is to suit a iPhone 4 with a cover (gear 4 ones fit snug)
Ash
Brilliant I'll look up the Brodit now. Thanks chaps!
Ok there are a few different versions, which models do u have? I'm not worried about the dock connector but it must tilt horizontally . With skin/cover or not? Thanks again chaps.
The one I have in the Dax is a simple holder with no power I use the USB cable as & when I need to, I have it in the horizontal / landscape
position with no problems, my gear 4 skin for the phone is rubber so it grips nicely and is held tight.
The spare one is this part number :516165 and is actually a pass through one, it had a fixed plug but you plug in the USB lead into the base and can
remove the iPhone without disturbing the cable. Yours for £40 if you want it.
Ash
I got a good one for my bike off ebay. Could be modded to fit. Weatherproof as well. Ill try find a link
