What are the advantages of a straight cut box over a semi helical box ?
faster gear change?
handle more power?
Handles more power. Faster changes may happen too, but if so it's due to uprated synchro bits rather than the straight cut gears. A dog box will
give a faster change though, but that's normally a whole new level of expensive!
Oh, they also sound brilliant!
[Edited on 6/2/07 by DIY Si]
straight cut box has less frictional losses... and, you have no axial thrust when using straight cut gears... also, as far as I am aware, straight cut
gears are a bit stronger..
now, shifting is a matter of using synchro mesh or dog angagement with no synchro rigns... but that has nothing to do with helical or non helical
gears, you can have a non synchro box with helical gears...
straight cut boxes have some free movement between gears and are much more noisy...
I've always found this one a bit strange because as I understand it, helical gears are inherintly stronger as the load is spread over 2 teeth as
opposed to one with straight cut.
Straight cut gears don't however produce the axial load that helicals do so maybe thats why they are seen as more robust.
Also, I would imagine replacement straight cut gears are made from better materials than the standard mass produced helical ones.
It is normally spread over 2 or more teeth, but only part of them so the difference in contact area is minimal. The teeth on straight cut gears tend to be thicker and made of better materials, so are stronger. Ie 1 big tooth is better than 2 halves of weaker ones.
They sound bloody awful - an incessant whine
I agree, they do sound awful. I am running a Trannex straight cut box and on the road it's a real pain but it does handle the power and on the circuit a bit of a whine is no problem.
Real reason is down to manufacturing it is much easier to cut straight cut gears.
I agree with Calvin! They sound delightful!
So racing cars use straight cut gears because they are easier to manufacture?
Thirded, I love the sound of my TranX box (the ratios are great too)
