Electric Reverse Switch
scootz - 1/5/15 at 08:18 PM
What type of switch are folks using to actuate their electric reverse systems?
Momentary or latching?
dave_424 - 1/5/15 at 08:32 PM
On a hayabusa powered buggy, I wired a main toggle switch with missile launch type cover that arms the reverse relay, then a momentary to nudge you back. Thinking of adding to the wiring so that you can only use reverse when in neutral
b3ngy - 1/5/15 at 09:03 PM
Yep, I use a similar system but I use momentary push button to engage the motor.
dave_424 - 1/5/15 at 09:15 PM
I wasn't very clear but I have one toggle to arm it and another momentary push button to reverse
40inches - 1/5/15 at 09:40 PM
I used a latching push button switch, with a small joystick controller. I also connected a relay to the brake light circuit
so when the brakes are applied the motor cuts out.
Reverse Switch Panel
scootz - 2/5/15 at 07:41 AM
Cheers guys
