Has anyone any info or wiring diagrams for Lancia wiring as I have to adapt the loom from a Thema to fit the Locost (lancia engine fitted) but I have
no diagrams.
Now stop laughing, I know the reputation Italian vehicles have for electrics or lack of them and I know that it will be an up hill struggle but I
won't let it beat me!
Any info would be helpful
Nick
std italian wiring on a lancia thema when first imported was that if a piece of wire got to some-where, then thats what it was connected to!
I jest not elctricians used to make a fortune rewiring lacia & fiat so that things worked on them when they came here on vehicles of that age.
Simplest idea is to look at a ford electrical diagram and just transpose the components. 12 volts is 12volts positive or negative. just use a bit of
common sense.
Enjoy.
i owned a Ducati once, every time i rode it it broke down due to the wonderfull electrics..
if its the ignition and injection u need ill have a look in my data books and make a drawing,need the year and engine size,2.0 i spose and what type of inj it has
Quote
"i owned a Ducati once, every time i rode it it broke down due to the wonderfull electrics.."
That was because you made the common mistake of riding it. Old Ducatis are just for looking at and listening to!!
theconrodkid
That is about the size of it. I have all the wiring from the car with connections switches etc, some will have to be removed and some kept. The
problem areas I am expecting to find are removing wires from the fuse box, old dashboard area and instrument display.
The ignition system is a Jetronic and the engine is a 2.0L turbo (pictures in the photo archive) from a D reg 1986 car. The turbo management may be
slightly problematic regarding items as dump valves etc.
I expect that I could probably work out the majority of the problems given time but a wiring diagram would be worth its weight in gold.
Nick
Oi! I still own a Ducati, made in 1996, and all the wiring connectors are those expensive, waterproof ones with rubber closures. Like
these ones from Vehicle Wiring Products.
Only had two electrical problems on it, and one of those was the starter solenoid - made by Hitachi in Japan!
Eddy
OK
I was really referring to the old ducatis from the 70/80.
To be truthful if I could afford one, new or old, I would have one yesterday.
But you can't deny the bad reputation they had a few years ago!
Nick
Also
Even the old 900sssssss were more reliable than my existing bikes.
1958 BSA A10SR
1961 BSA A10GF
Nick
The big problem I had was recurrent failure of the rectifier/regulator. One time it failed on the autostrada just outside Milan (we were going to
watch the WSB at Monza) and I was stuck there until the Monday morning when the shops opened up, after all my so-called mates bu66ered off back to
Blighty. I was woken during the night by a stand-up row outside my hotel bedroom between a young couple - the bloke was obviously pi$$ed and his
fiancee was giving him a right earful. Turned out to be Jamie Whitham and Andrea!
To cap it all, once I'd fixed the bike and was heading off northwards, I was pulled over by a couple of Italian police for having noisy exhausts.
On a 916! In Italy! Anyway, I pointed out that within the hour I'd be over the border into Switzerland and no longer their problem they let me
go. They did ask to see my licence, but that had blown out of my ruckrack when it unzipped at about 120mph on the way down off the Alps a couple of
days previously...but that's another story!
Eddy
I had an Alfasud and the electrics on that were amazing. I didn't go out after dark because people used to think I was flashing at them. But the
engine was brilliant, it didn't like Bosch plugs though.
yours, Pete.
theconrodkid
Any luck with the wiring digrams?
Nick
need to know what year,what injection system or you running carbs etc
The injection system is a Jetronic, the ignition is Bosch and the engine is a 2.0L turbo (pictures in the photo archive) from a D reg 1986 car
Now I have some doubts so I've just had a look and there is a Bosch controll box (ECU I think), a Magnetti Marreli controll box (Ignition
Controll) and the air inlet meter is Bosch.
I hope this makes sense.
Nick
nothing italian makes sense but ill have a look n see
right got the wiring diag for inj,someone borrowed the ignition book ,mail me yr addy and ill send a copy
