Author: Subject: Can you...
james h
posted on 3/6/09 at 12:35 PM Reply With Quote
Can you...
mount your gel batteries on their side?
Thanks,
James
dan__wright
posted on 3/6/09 at 12:39 PM Reply With Quote
yes ......
i hope as mine is on its side!
as long as there sealed you can mount them however you like.
Mr Whippy
posted on 3/6/09 at 12:45 PM Reply With Quote
yip
Vindi_andy
posted on 3/6/09 at 01:30 PM Reply With Quote
yes definately thats part of the beauty of them
That and their size
macspeedy
posted on 3/6/09 at 02:05 PM Reply With Quote
ive heard that they say yes but in some cases they leak..
tomgregory2000
posted on 3/6/09 at 02:37 PM Reply With Quote
you can mount them any which way you like
Land Locked
posted on 3/6/09 at 02:40 PM Reply With Quote
We have a local garage door opener company who took the battery manufacturers at their word and used the gel batteries upside down. Only till the claims started coming in, they've redesigned the batteries into a sealed box and they now sit right way up. No official numbers available, but from what I've been able to put together they had around 5% returns for leaky batteries. With 2 batteries per unit that makes it around 2.5% chance of a leak.
b16mts
posted on 3/6/09 at 03:21 PM Reply With Quote
Surely that'd be a 10% chance?
who says you can't drive a kit car when you're 6'5"?
james h
posted on 3/6/09 at 03:23 PM Reply With Quote
All sounds good, you just have to get the CofG a little bit closer to the ground...
MikeRJ
posted on 3/6/09 at 04:02 PM Reply With Quote
Neither gel batteries (as used in Burglar alarms etc) nor AGM batteries (such as the Varely Red top and the Odyssesy) are designed to be used or charged upside down. They can be mounted in any other orientation though.
[Edited on 3/6/09 by MikeRJ]
james h
posted on 3/6/09 at 04:25 PM Reply With Quote
Ah thats ok, its on its side now
Land Locked
posted on 3/6/09 at 06:34 PM Reply With Quote
Only one of the 2 fail at a time.
re. the statement that they can't be upside down, the manufacturers said ANY way including upside down. Personally, I'd want a very good reason to mount them any way other than flat and right way up. Seen too many of them leak over the last couple of years.
That said, there is one premium manufacturer (Japanese I think) who makes em in grey, that I have not seen a leaky example of.
