antimony
| posted on 15/7/09 at 08:27 AM |
Copper slip on eletrical connectors.
Hi folks.
Is copper slip conductive?
I have a circuit board with an intermittent power loss fault. Rather than trust my very dodgy soldering, I thought a bit of copper grease may fill
any cracks in the solder.
Good idea or utter rubbish?
| posted on 15/7/09 at 08:35 AM |
Rubbish, solder it or get some one who can
thunderace
| posted on 15/7/09 at 08:37 AM |
stick the pins of a multi meter in it and do a continuity test
iank
| posted on 15/7/09 at 08:54 AM |
You can get high silver content paint that is conductive and might work, but soldering will be much more reliable and probably easier.
Anonymous
| posted on 15/7/09 at 08:57 AM |
nope - put the tub down.
you need to examine visually i.e. look at the joints to see if you can spot what is known as a "dry joint".
read this
any dodgy ones, you would put a small amount of solder onto the tip - the motled solder help to conduct heat - place onto joint so it mels, and add a
bit more solder to it. sometimes a bit of flux on the joint helps (plumbers flux from B&Q will work).
the joint should look like a little mountain of shiny sholder that covers the whole pad and rises maybe 1 - 2 mm up the wire.
as ^^^ say, a multimeter, if you have one, would help too.
the example of a good joint in the linky does not look all that good to me.
top left corner here:
BTW - what circuit is it?
| posted on 15/7/09 at 08:58 AM |
and much much cheaper!!!
that stuff is a last resort and is usually for restoring broken tracks - also for low current stuff.
| posted on 15/7/09 at 09:46 AM |
Copaslip is not conductive it is a good insulator if you put it on thick enough. I've repaired tracks with a wire bridge rather than just rely
on the solder.
britishtrident
| posted on 15/7/09 at 09:47 AM |
And also for repairing heated rear windows.
[/I]
| posted on 15/7/09 at 11:06 AM |
I'd definately re-solder it. For the cost of one of those conductive paints you could get a nice soldering iron and some solder And it
won't flake off as soon as you put a few mA through it....
nz_climber
| posted on 15/7/09 at 10:24 PM |
Maybe get someone who can solder it nicely to have a go first
Also the picture above is some of the worst soldering ever!!
http://aarons7.wordpress.com
Staple balls
| posted on 15/7/09 at 10:36 PM |
Yup, solder, there's no good reason to do otherwise
