Thinking about it
| posted on 31/7/09 at 05:28 PM |
Megajolt difference
What is the difference between V3 and V4 and any real advantage either way?
snapper
| posted on 31/7/09 at 05:33 PM |
Loads of new features, USB not the old RS232.
But V3 is good so pays your money etc.
I eat to survive
I drink to forget
David Jenkins
| posted on 31/7/09 at 05:36 PM |
V3 uses 'ordinary' component, e.g. resistors with wires, and V4 uses surface-mount devices. If you're making a kit then
surface-mount is more of a challenge.
V4 is more modular, and you can add things like a hard rev limiter very easily.
Both do their job well - apart from that, AutosportLabs only sell V4 now.
paulf
| posted on 31/7/09 at 08:59 PM |
Its not usb just a RJ 11 plug instead of a 9 pin serial lead although still needs a serial port or USB adaptor at the PC end.
Im just about to build one for someone, have built lots of the V3s but this one looks a bit more fiddly.
Operation wise they all do the same basic job and most of the newer features can be added to an older version.
Pau
