rob2005
| posted on 17/9/09 at 05:50 PM |
Help needed
Last week I decided I wanted the wiring loom moved from my engine bay and hiden.
Well tonight got it all back in running and all working ok ..... Or so I thought??!!
The car (zx12 BEC) idles fine and revs at idle but as soon as I go to pull away the fuel pump cuts out and stays dissingaged for u till I turn the
ignitin on and off a few times.
I'm stumped guys, checked everything andbefore I messed with it the car run and drove excellent.
Any suggestions welcomed.
Fortune favours the brave!!
Guinness
| posted on 17/9/09 at 05:56 PM |
Sounds like either the clutch switch or the neutral switch.
Mike
rob2005
| posted on 17/9/09 at 06:00 PM |
Hi mike, how can I check the switches?
I have a gear indicator and that's shoing 6th gear at idle but when I select the gear it shows 1st or 0 for neutral etc.
I think it's because I've shared it's live with the power commanders live. Could this be it do you think?
Davg
| posted on 17/9/09 at 06:01 PM |
Tilt switch sensor? been moved and now facing wrong way?
r1_pete
| posted on 17/9/09 at 06:03 PM |
Exactly when does it cut out? when you press the clutch, when you engage gear etc, does sound like the sidestand/gear lockout area..
rob2005
I have moved the tilt sensor but it is sti facing up as the arrow shows.
However all my gut feelings are pointing to that as it may be on a slight angle. I'll chck that first I think.
rob2005
| posted on 17/9/09 at 06:05 PM |
It cuts out as soon as you go to pull off, I can pull off slowly and let the car crawl but if I touch the throttle it cuts out and fuel pump stays
off.
Davg
| posted on 17/9/09 at 06:06 PM |
Carefull with the arrow facing up thing. On the R1s 'up' means the face is up!
from your last post I would say def the tilt switch.
[Edited on 17/9/09 by Davg]
r1_pete
| posted on 17/9/09 at 06:07 PM |
99.99% its a tilt sensor issue then.
rob2005
| posted on 17/9/09 at 06:24 PM |
Yes it's official I'm a pillock. I've fitted it totally wrong and on it's side don't ask me how.
well I'll reposition it in the morning.
Thanks guys!! God I love this site
Davg
| posted on 17/9/09 at 06:28 PM |
Glad that's got it, cheers D
Guinness
| posted on 17/9/09 at 08:47 PM |
