FrankP
| posted on 4/10/09 at 10:54 AM |
ZETEC Not Firing Up! Help Please!
Hi,
I have just wired up the EDIS unit in the car to the MS1 extra.
When I crank the car I hear the fuel pump prime. On the megatune I see an RPM (about 235 RPM) and can see the injectors being pulsed.
When I put a timing light on the HT leads it does not flash - I am assuming I am no getting a spark to the plugs.
I have tried 2 edis units and 2 coil packs now!
Can anyone please help?
Frank
prawnabie
| posted on 4/10/09 at 10:56 AM |
I though the edis unit was the coilpack?
| posted on 4/10/09 at 11:03 AM |
no.
the EDIS is a black plastic rectangle containing the electronics - see above- labelled EIDIS
the coil pack is a big block to which the 4 plug leads connect - above the EDIS.
you need to check that the coil pack is working - if you remove the plugs - helps eninge turn over easier) and leave on engine so the thread is
earthed, do you see spark at all?
if not, then you need to see if the EDIS is swicthing the coils - in theory you can test the coils by
blakep82
| posted on 4/10/09 at 11:04 AM |
nope. 2 sepearte things, connected by 2 wires.
anyway, have you checked your wiring in the edis?
my dad did mine, wired all the earths and +12v together. no power to anything. sorted that and it fired right up. 12v going to the coil ok?
________________________
t16turbotone
| posted on 4/10/09 at 11:05 AM |
does ms1 support edis??
prawnabie
| posted on 4/10/09 at 11:06 AM |
Ahh I see now - all this electrickery sounds confusing - give me carbs and a dizzy anyday lol
FrankP
| posted on 4/10/09 at 11:29 AM |
Hi,
Yes, the ms1 Extra can handle the edis unit you have to make some internal mods.
The wiring seems pretty simple
Are there any checks I can do - how can I test the vr sensor -
Frank
robocog
| posted on 4/10/09 at 11:45 AM |
What I would do
Check you have 12v at EDIS AND coilpack in crank position as well as ign on!
(V easy to get wrong!)
If megatune recognises its going into crank mode and showing an RPM -then you have inadvertantly already checked the VR sensor, and ruled it out
surely?
(if its wired the same as mine - Squirty gets RPM info from EDIS- which gets it from the VR)
I would also think that EDIS has voltage - otherwise Megatune would also not recognise crank mode as it wouldnt get pulses from EDIS without
voltage??
I would just check you have 12v at coilpack and EDIS with ignition in crank as well as run position
then look to check the wiring between EDIS and coilpack has continuity and is wired 100% right
Regards
Rob
FrankP
| posted on 4/10/09 at 01:16 PM |
How do you test this?
Frank
| posted on 4/10/09 at 01:56 PM |
quote: Originally posted by FrankP
Hi,
Frank
Might save a load of hassle to actually check for spark at the plugs???
robocog
| posted on 4/10/09 at 05:03 PM |
To test you will need one 12v bulb with wire "tails" or multimeter set to volts DC and a voulenteer to turn the key into various
positions
Stuff one wire of bulb onto middle coilpack connector (from EDIS) and other to chassis (this should either light the bulb or show 12v on multimeter
with ignition key in both run and crank positions)
HTH
Also would take plugs out and lay them on the engine somewhere metal and see if there is a spark when cranking first..but assumed you would have done
this ??
Regards
Rob
big_wasa
| posted on 4/10/09 at 06:49 PM |
where in the world are you ? if local I can give you a hand.
FrankP
| posted on 4/10/09 at 07:05 PM |
I live in Flitwick - a couple of miles from J12 and 13 of the M1
big_wasa
| posted on 4/10/09 at 07:13 PM |
Yeh not a million miles but not local either.
The edis will fire the coil pack with out being conected to the megasquirt at 10 deg btdc.
If your not getting any spark, first thing to check is the crank pick up sensor plug wiring is the correct way around.
[Edited on 5/10/09 by big_wasa]
FrankP
| posted on 5/10/09 at 04:45 PM |
Hi,
Just tried with a spark plug no spark
Will turn the wires around on the vr sensor to see what happens .....
