Author: Subject: Indicators work and Hazards dont????
FFTS
posted on 19/10/09 at 01:52 PM Reply With Quote
Hi I think its on a sierra colum and the hazards button is on the top of it. When its pushed down the indicators work ok.. when its pushed to move into the up position the indicators stop but the hazards dont start???
In answers please bare in mind you are answering to a electrical/mechanical retard hahah
Chris.
mackei23b
posted on 19/10/09 at 03:16 PM Reply With Quote
Now this may depend on whether you have the newer or older switches, on mine pin 30 (red wire) on the indicator block should be perminant live. If it's not then the hazards wont work, I'd check this first.
If I remember right when you use the harzard switch also switches from 'switched live' from ignition (indicators) to 'permimant live' for the hazards. This is so the hazards can be switched on without the ignition.
Hop this makes sence?
Ian
[Edited on 19/10/09 by mackei23b]
