Findlay234
posted on 27/10/09 at 09:40 AM |
NAS fog light from CBS no "B" or "F"
Ive got a NAS set of lights from CBS and none of the rear red lenses have a "B" or "F" mark on them.... as i read the IVA
manual it states that the fog lens must have either of these markings... I called CBS to query this incase they had accidently put three stop/tail
lenses in instead of two and a fog lens but the phone said no it was fine it would pass with that. Ive checked the lamps and they are correct
2xstop/tail and 1xfog (higher intensity)
Surely this cant be right?
AdrianH
posted on 27/10/09 at 09:51 AM |
One of my fail points was because the fog was not marked with the B or F mark. Luckily I have found another make that matches and is marked.
Adrian
Are they LED or bulb?
[Edited on 27-10-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Findlay234
posted on 27/10/09 at 09:55 AM |
They are bulb, well i guess the next question would be how i would go about getting a matching IVA passable lens fitted so it matched the NAS plinth
or at least matched the hole ive already cut in the body.....
PS, adrian, another thing about the fog lights, i see on your build diary you failed because you could also turn the fog on when the side lights were
on... to me the wording in the manual says that the fog must illuminate when either main or dipped is on, it certainly doesnt say.... only when main
or dipped are on..... I guess this comes down to testers interpretation of the rules.... if so im going to also have to wire in a relay to switch it
from the light switch as well.....
[Edited on 27/10/09 by Findlay234]
RickRick
posted on 27/10/09 at 09:57 AM |
i also failed on this not sorced from cbs, but same lights, needs b or f and an internal reflector i'd make them change it. I'd had
mine from ebay for ages before my sva think i ended up getting a landrover rear fog as this was marked up correctly i think it was made by pelie or
something
RickRick
posted on 27/10/09 at 09:58 AM |
i think this will be right but i'd send the seller an email just to check for the marking
http://cgi.ebay.co.uk/Land-Rover-Defender-110-90-Rear-Fog-Light-Assembly_W0QQitemZ180413474887QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?has
h=item2a017b2847
Findlay234
posted on 27/10/09 at 10:05 AM |
Thanks rickrick, will call that ebay seller...
AdrianH
posted on 27/10/09 at 10:14 AM |
Yep I failed because I could put them on from side lights so I have added a relay from the earth return to the headlight switch for that.
Do you have an auto electrical place near yo for the lights that is where I got mine from and gives a chance to see before buy.
Adrian
Findlay234
posted on 27/10/09 at 01:21 PM |
Well its been a productive lunch break, got a relay from Maplin (what a great store!!!) been to BnQ for some stuff, called the ebay seller (thanks to
Rickrick) who went to the back to get the lens and read out that there was an F mark before the EII. so i bought. ive also sent off for a cover note
from insurance for the drive to IVA....
I still think that the ruling about fogs only on when the main and dipped are on is definately not stated word for word in the manual and is really
out for interpretation.
