kj
posted on 5/11/09 at 02:12 PM |
Fazer Fuel Pump
Can anyone tell me what is the live wire on a fazer fuel pump, it only has 2 wires one is black and the other is black/blue.
Just don't want to f&^* it.
tegwin
posted on 5/11/09 at 03:03 PM |
Connect it up... if the car goes backwards you have it wrong!!!
The black is usually ground, and the Black with blue stripe is usually +ve
matt_gsxr
posted on 5/11/09 at 04:12 PM |
if its a carb pump (i.e. one of those mitsubishi ones) then they work either way around. I know it sounds unlikely.
One way around is better than the other, so you could check the flow rate with a bucket of water.
On mine black was ground, but mine was kawasaki engined (although mitsu. pump as they all seem to be).
Matt
kj
posted on 5/11/09 at 04:35 PM |
It is a carb one, so i will check it.
thanks
flibble
posted on 5/11/09 at 05:32 PM |
In the Haynes manual I traced the black back to earth.
Kev
