carlknight1982
posted on 16/11/09 at 02:39 PM |
Minimum wiring req for pinto
Hi guys, due to a change of plans i am now fitting a 2.0L pinto into my roadster, It has a points type dizzy, im not sure the coil i have is for that
type of dizzy, how do i tell? also whats the minimum wiring i need to get this to run.
Also I have a megajolt from my zetec, what would i need to do to the pinto to get it to run on megajolt.
thanks guys
Logic will get you from a A to B
Imagination will take you everywhere.
tegwin
posted on 16/11/09 at 03:05 PM |
Minimum wiring for points ignition?
+ve supply to coil..... connect coil to dizzy points...
+ve to starter and starter solonoid... jobs a goodun!
www.verticalhorizonsmedia.tv
RichardK
posted on 16/11/09 at 03:07 PM |
use the mega jolt, you'll need a trigger wheel, sensor, coil pack and ht leads to suit and an edis4, think that's some picture in my
gallery how I put it all together!
Rich
Gallery updated 11/01/2011
bj928
posted on 16/11/09 at 06:58 PM |
Rich
Who didn't read the first post then, he is using a pinto with POINTS, so just needs the one ignition wire to the coil, and a trigger wire to
fire the starter, don't wire the coil to the battery or you will fry it as it will be on 24/7, it needs to be ignition fed or at least a switch
to switch on and off.
also, the ford coil is 9v, so would need a ballast resister to stop the coil eventually buring out, but if you use a british leyland coil, they are
12v so don't need the ballast resister ( think the ceramic thing on a ford was a ballast resister, sure some one will tell me).
RichardK
posted on 16/11/09 at 07:13 PM |
I was replying to the question in the 2nd para
thanks guys
Rich
mark chandler
posted on 16/11/09 at 09:44 PM |
I believe you can run megajolt from the distributor, screw down the base plate and solder the advance mechanism, talk to Phil at extra EFI
