londonsean69
| posted on 30/11/09 at 08:49 AM |
Non KC - Crazy Astra Horn Problem
Morning
My Astra (MK3 2.0 Sport) decided to have a fit at 4.45am this morning. The horn just started blaring.
Took me a while to realise it was my car, so shot downstairs and out into the p155ing rain, in me boxers
I thought it must have been the alarm, but was able to disarm and arm the alarm with no effect on the horn.
In fact, at one point I managed to set the alarm, then open the door. Alarm started going off as well (By now I was waiting for a neighbour to start
chucking housebricks)
In deperation I popped the bonnet, about to cut cables/pull fuses, at which point it just stopped.
Any Ideas?
*I didn't think it was connected to the alarm system (Clifford) but am trying to get a copy of the user manual
*Possible short circuit because of rain?
*Crap car
It started and ran fine for the run in to work this morning
Mr Whippy
| posted on 30/11/09 at 08:57 AM |
My old cavalier had a factory alarm that used the main horn, you may have that too
londonsean69
| posted on 30/11/09 at 09:08 AM |
As well as the Clifford?
Seems strange, because I don't have any sort of fob except the Clifford. I'll have to get me head in the wiring diagrams in the Haynes
Book of lies
| posted on 30/11/09 at 09:09 AM |
that would be my reaction. aren't horns wired permanently live? so some moisture on the esrth wire may have been enough to complete the
cricuit.
get to the horn, remove both push on connectors and spray WD40 or apply vaseline and then fit back on making sure they re on tight.
test horn.
it it ewasd alarm, did not the siren go off and indicators flash too?
londonsean69
| posted on 30/11/09 at 09:22 AM |
cricuit.
test horn.
It was my first thought. Actually, it was my second, the first was "Shut the f**k up"
I did have an M25 run last night, and it was lashing down.
But, the car was parked up by 11pm, and this didn't happen till 4.45am, so maybe seeped in somewhere.
The horn was continuous, with no indicators flashing, which makes me think it wasn't a factory alarm.
The indicators did flash when I set/reset the Clifford.
I've got some proper contact cleaner, so will give it a swizz later. The horn was fine on the way to work though, I did give it a little toot
to test it.
I think I might sling a letter into my neighbours houses later, because it took me a few minutes to get it to shut up.
dhutch
| posted on 30/11/09 at 01:54 PM |
Do nothing, unless it does it again?
Engine light came on on the pug a week ago after vigous run though the rain and floods, not seen in since, runs fine. Sod it!
Daniel
dhutch
Also try astra forums to see its its common and if its likely to reoccur?
