bj928
| posted on 16/12/09 at 12:26 AM |
side lights
can i wire the side lights all on 1 fuse or do they have to be wire and fused left and right or maybe front and back.
blakep82
| posted on 16/12/09 at 12:29 AM |
as far as i know, you're allowed to put the on 1 fuse (same with dipped and full beam) but makes sense to wire them left and right seperately.
if you blow a fuse you don't want to lose the lot
________________________
l0rd
| posted on 16/12/09 at 06:29 AM |
more fuses = more weight
adithorp
| posted on 16/12/09 at 08:25 AM |
Hmm...Good point. You wouldn't want to overburden that engine!
Yes, you can use one fuse but seperate left and right circuits is more usual.
adrian
http://jpsc.org.uk/forum/
l0rd
| posted on 16/12/09 at 08:49 AM |
adrian
I see your point, but if you consider the complexity of the wiring diagram and the weight gained from fuses, wiring etc... -0.0001 Hp losses
[Edited on 16/12/09 by l0rd]
turbodisplay
| posted on 16/12/09 at 11:37 AM |
Side lights, single fuse. Dipped and main beam seperate fuses left and right, giving 5 required.
Edit : Not the law, but makes a lot of sense.
Darren
[Edited on 16/12/09 by turbodisplay]
speedyxjs
| posted on 16/12/09 at 12:31 PM |
I have sides on one fuse and H/L on one fuse (hadn't thought about losing them so may rewire yet)
bj928
| posted on 16/12/09 at 05:36 PM |
thanks for the replys, now i know what i'm doing.
