Author: Subject: couple of quick leccy questions ?
givemethebighammer
posted on 2/5/04 at 08:55 PM Reply With Quote
1. What sized fuse / wire for a Facet Blue top solid state fule pump ? Guessed at a 14/030 witha 10A fuse but could be wrong.
2. What sized fuse for my GEMS ECU, bearing in mind that the current to the low tension side of the coil also uses this feed.
thanks... more to come lighting relays next.
