Author: Subject: acewell clock not working.
Danozeman
posted on 8/4/10 at 07:29 AM Reply With Quote
Does anyone know if there is a battery you can change in an acewell. The clock on mine always resets to 12:00 when you turn the ignition off and doesnt stay displayed. All the other memories stay so there must be some power still there.
Dan
flak monkey
posted on 8/4/10 at 07:35 AM Reply With Quote
I think the clock needs to have a permanent live supply to the dash to keep the time right. Everything else is remembered even if the power is removed/batt disconnected so sounds like you dont have a perm live?
Sera
http://www.motosera.com
turbodisplay
posted on 8/4/10 at 07:54 AM Reply With Quote
As above you need power for the clock to count time. Memorry does not require power, just like a USB memorry stick.
Darren
Danozeman
posted on 8/4/10 at 09:29 AM Reply With Quote
ah just looked at the wiring diagram again. Looks like the brown is permanent live. Im sure thats connect to something though, il have to check when i get home.
Dan
55ant
posted on 8/4/10 at 09:53 AM Reply With Quote
or only go out for a drive at lunch time?
Danozeman
posted on 8/4/10 at 02:14 PM Reply With Quote
and be out and back in less than 1 minute.
Dan
