Author: Subject: whats the standard size fan switch?
blakep82
posted on 21/4/10 at 08:25 PM Reply With Quote
for a vauxhall engine. i'd probably be best sticking with the one from the car the engine's out of...
so whats the standard thread sizes?
and what are vauxhall size?
need to get a thing made so i can fit them in the radiator hose
________________________
boggle
posted on 21/4/10 at 08:43 PM Reply With Quote
blake....
send it to me and i will make you a manifold block....
u2u me for details
blakep82
posted on 21/4/10 at 08:46 PM Reply With Quote
whats a manifold block?
i haven't got any of the pieces yet. well, i've got a sensor for the gauge, and the ali tube. not got a fan switch yet though. don't know what one to go for
boggle
posted on 21/4/10 at 08:53 PM Reply With Quote
ok...
im thinking you want a solid block with 2 holes drilled and tapped to fit the sender and fan switch, with a tube eitherside to join into the heater hose?? letting the coolant through the middle?
u2u me for details
blakep82
posted on 21/4/10 at 09:04 PM Reply With Quote
pretty much. what i had in mind was a sort of 'match box' size bit of ali, with the holes drilled and tapped.
the idea was to then get this welded onto a piece of ali tube, which has a hole cut in the top to accomodate the ali block
boggle
posted on 21/4/10 at 09:09 PM Reply With Quote
i can do this for you...
i can get a vectra x20xev fan switch for pennies, all i need is your temp switch, and hose I.D. and i will make it for you..
have you got your mount yet???
u2u me for details
blakep82
posted on 21/4/10 at 09:11 PM Reply With Quote
cool, well, i'll get on the lookout for a x20xev fan switch (are they normally in the back of the cylinder head? i might have one if thats where it is...)
once i have all those, if you can weld it and bead the hoses, i'll send you all the bits?
mount's not arrived yet when was it posted? fingers crossed for tomorrow!
boggle
posted on 21/4/10 at 09:16 PM Reply With Quote
was posted on monday.....
like i say..if you send me your temp sensor i will sort a fan switch and make the whole thing....
u2u me for details
blakep82
posted on 21/4/10 at 09:23 PM Reply With Quote
good man, i'll get on it need to try and find my sender... bought it years ago, put it away safely. can't remember where...
if it was posted monday, should really have been here today, but they can be a little slow here, so hopefully tomorrow
boggle
posted on 21/4/10 at 09:24 PM Reply With Quote
i dont know if that ash cloud has slowed things???
i sent out two jobs on monday and neither have reached there destination yet.....
u2u me for details
blakep82
posted on 21/4/10 at 09:29 PM Reply With Quote
ah, a very good point. remember that top gear race from lands end to john o groats? think there would normally be a plane bringing stuff up here from your way. sending by road might take a little longer, ie a day in the sorting office, a day to drive it up, a day in the sorting office here, out to the local post office, then out with the postie. guess its likely to be about 4 days delivery on post now
britishtrident
posted on 22/4/10 at 07:13 AM Reply With Quote
A fan switch is best mounted on or close to the radiator.
Easy way to fit a fan switch if the rad dosen't have a tapped holes is an adaptor in the top hose tapped for a M14 fan switch (as used on 1980s and 1990s Volvo and BMW various swiitching temps available)
Temperature sensor should be on the cylindr head hot side of the thermostat.
[Edited on 22/4/10 by britishtrident]
[/I]
