Author: Subject: battery Again: this one any good?
omega0684
posted on 24/4/10 at 01:28 PM Reply With Quote
battery linky
Dangle_kt
posted on 24/4/10 at 01:40 PM Reply With Quote
expensive for a no name - get a good make if you can.
Andy Bates sells good ones that are lightweight but good qaulity and reasonable price.
That is essentially a motorbike battery - but a cheapo one.
richardh
looks good
Time for a change!
daniel mason
posted on 24/4/10 at 01:53 PM Reply With Quote
you not fancy one of the ones recomended by nigel dean in kit car mag? cant remember the name of them off hand,but they looked quality!
omega0684
posted on 24/4/10 at 02:33 PM Reply With Quote
i dont get the kit car mag, do you have a copy that you can dig a name out from?
Confused but excited.
posted on 24/4/10 at 02:36 PM Reply With Quote
"THIS IS A HUGE 10KG LIGHTER(approx) THAN A STANDARD 43AH BATTERY & AROUND 1/2 THE SIZE."
No sh1t Sherlock. That's probably because it is only a 20AH battery!
big-vee-twin
posted on 24/4/10 at 05:02 PM Reply With Quote
I've just fitted one like that to my motorbike, it does have a 1600 engine, so I would imagine it would be ok for a small car engine.
But I would say if the car engine takes a few times to start it would flatten pretty quick if you have an engine which is a good starter should be ok. If its a tempremental starter I would go for something with more Amp hours.
http://www.triangleltd.com
bimbleuk
posted on 24/4/10 at 06:24 PM Reply With Quote
I've been using standard 19Ah bike batteries for several years. Actually the last one has only just failed after 4 years use.
That was with a 1.6 4AGE with quite high CR at 11:1. No you can't expect it to continually crank the engine but I had a decent ECU and map so starting was quick.
40inches
posted on 24/4/10 at 07:35 PM Reply With Quote
It's the RMD Rally Design one.Here
britishtrident
posted on 24/4/10 at 07:40 PM Reply With Quote
Very dubious --- No way believe the claim for cold cranking current of 680 amps, to get that sort of cold cranking current you need a very large heavy duty battery as normally found in a 2 litre diesel.
If you want a small light battery a type 054 as fitted to some small Japanese vehicles inlcuding the Suzuki Carry 10kg 35 amp hours 340 Cold Cranking Amps SAE.
[/I]
MikeRJ
posted on 24/4/10 at 08:39 PM Reply With Quote
I agree, even the very expensive Odyssey or Varley batteries with the spiral plates can't achieve even half that CCA in the equivalent capacity.
I suspect it's an absorbed glass mat motorbike battery to be honest.
scooby_doo_do
posted on 28/4/10 at 07:31 PM Reply With Quote
i know this may be a bit of overkill and too big, but i have a nearly new PB gel racing battery http://www.tripkings.co.uk/stuff/large/0020.jpg
I used it in my Ultima Spyder as i thought the red top 40 was dead.. only to find it was the starter motor.
It's the same size as a varley red top but more powerfull.
Craig.
Westfield 2.0 XE Redtop
