Author: Subject: Weird speedo problem
Dave J
posted on 7/7/10 at 08:10 AM Reply With Quote
Hi all,
Up untill recently, I have been running with a Mallory dual point distributor on my V8. My instruments are ETB electronic dials...speedo, tacho etc.
At the weekend I ditched the points in favour of a Mallory E-Spark electronic ignition conversion module which sits in the distributor in place of the points (infra red beam with a chopper plate).
Now here is the problem;
On acceleration my speedo shoots up to 90mph+ (actual speed accelerating through 25-30 mph). Once I have gone through 2000rpm or not accelerating any more at a steady cruise, the speedo settles down and reacts normally, until I slow right down or stop then accelerate through the gears again, then once again the speedo goes crazy.
The electronic tacho behaves normally. The car is running very well on the new system.
The Tacho gets it's pulses from the coil. The speedo gets its pulses from magnets fitted to the prop.
I tried covering the leads from the electronic module to the coil in baco foil and then earthed it just in case excessive RF is being emitted and is having an effect on the speedo. this didn't do anything
I've been in touch with ETB to see if they have any idea what the problem might be. Whilst being extremely helpful, there was lots of head scratching going on, so no joy there.
The speedo was behaving perfectly well prior to the conversion, so there is obviously some sort of feedback getting to the speedo head, possibly coil related??. The electronic module is connected to the coil through the ballast resistor as per instructions.
Can anybody shed any light on this?
Many thanks.
Dave
posted on 7/7/10 at 08:50 AM Reply With Quote
strange.
1. does the speedo go lulu when staionary and revving engine?
2. when coasting down a hill with low rpm, does speedo read correctly?
3. what sort of cable do you have from the speedo pick up?
4. you have checked the magnets and speedo pick up are secure?
5. if you move speedo pickup away from the magnets, does the speedo go mad?
6. I'm sure you are but you are using resistive ignition leads?
7. is speedo pick up indictive or hall effect type? (2 or 3 wires?)
RazMan
posted on 7/7/10 at 09:12 AM Reply With Quote
Sounds like some interference is causing crosstalk somewhere. Have you used shielded cable or 'twisted pair' for the speedo sensor and any other input related stuff? I had chronic misfire problems until I shielded my crank sensor wire.
[Edited on 7-7-10 by RazMan]
Raz
Dave J
posted on 7/7/10 at 01:31 PM Reply With Quote
Thanks for the replies. here are some answers to your questions;
02GF74 asked:
No it remais on zero.
When coasting at low speed around 1500 revs, say in 3rd gear, it does tend to behave irratically as described.
The cable is part of the loom supplied by Luego so I assume it's fit for purpose (no probs untill I fitted the Mallory conversion)
From memory there are two wires from the sensor ,multi strand, about 1 mm dia.
Yes, all ok
Not tried this.
Yes, Magnacor HT Leads
It is inductive (2 wires...red and black)
All the wiring is pretty standard stuff, no shielding. Twisted pair I suppose as there are only two wires from the speedo sensor.
I tried shielding the wires coming out of the distributor electronic module to the coil, but this didn't have any effect.
The speedo sensor is toward the rear of the car by the prop, so I would be amazed if that was picking up any interference (who knows??).
Hope the answers are some use.
Thanks again guys.
All the best
Dave
[Edited on 7/7/10 by Dave J]
Canada EH!
posted on 7/7/10 at 01:39 PM Reply With Quote
Sounds like electrical interference. The 60's Corvettes had shielded distributors and wires on models equiped with radios. do you have a GRP Scuttle? I had to shield the ignition on my fathers GRP boat for the same reason.
Dave J
posted on 8/7/10 at 07:27 AM Reply With Quote
Thanks for your thoughts. I do indeed have a grp scuttle. It has crossed my mind to put a metal shield in front to see if that will shield any interference, but this will involve some serious work, so I was hoping somebody might have had a similar experience with a simpler fix.
I'll probably finish up shielding everything in sight.
I'm wondering if there is a coil issue, as somebody mentioned that a different coil is needed for electronic ignition over points type. I've never come across this, anybody know if this is the case??
Dave
