Author: Subject: adding a caharge light?
dilley
posted on 28/9/10 at 10:52 PM Reply With Quote
I have a start button and would like to wire it through a charge lamp so the button can only work when the lamp is on , problem is the Busa has no battery charge lamp!!! any ideas? can one be fitted?
BenTyreman
posted on 28/9/10 at 11:16 PM Reply With Quote
Why not use the oil pressure warning light instead?
dilley
posted on 28/9/10 at 11:44 PM Reply With Quote
Genius! I wish I had thought of that....
posted on 29/9/10 at 04:05 AM Reply With Quote
Sounds good, that's decided me to add a start button!
RAYLEE29
posted on 29/9/10 at 02:31 PM Reply With Quote
you will need a relay of some sort too but you knew that didnt you
Ray
