dilley
posted on 3/10/10 at 12:29 PM |
fuse box
I am trying to source a fuse box for my loom, I would like one that I can put one main cable into and then each circuit from that, so far I am having
no luck! they all seem to need connecting both sides of each fuse. I hope that makes sense?? any ideas?
dan__wright
posted on 3/10/10 at 12:38 PM |
you need one with a busbar but they are not very common, i used the modular system that vwp sell, its has 4 or 5 slots and you add modules for what
you need, relays eyc, they do busbar terminals for the mini fuse module.
FREE THE ROADSTER ONE…!!
AdamR
posted on 3/10/10 at 12:41 PM |
VWP sell a couple of boxes that do what you want, though they're a bit pricey and bulky. See the 6 way and 12 way fuse blocks, about 2/3 of the
way down the page here.
[Edited on 3/10/10 by AdamR]
alexg1965
posted on 3/10/10 at 12:48 PM |
Another vote for the VMP modular system. Very flexible and allows you to create a bespoke fuse/relay box. Probably a more expensive option though.
tegwin
posted on 3/10/10 at 01:37 PM |
The 1999ish mondeo has a really nice engine-bay mounted fuese/relay carrier.... it ended up in my TVR...worth a look if you havea friendly
breakernearby
www.verticalhorizonsmedia.tv
RichN
posted on 3/10/10 at 04:43 PM |
Try contacting Premier Wiring as they use busbars in their looms. I asked for some for the same the reason as you and got a fuse box and a busbar to
fit.
Davegtst
posted on 5/10/10 at 04:35 PM |
What about this? I've been searching for ages for something decent and this is the best i can come up with.
http://www.cbsonline.co.uk/wired-fuse-box-8-way-fbw-538-p.asp
dilley
posted on 5/10/10 at 10:23 PM |
I think I may go with the modular fuse/ relay box from VWP, not cheap but will look great, I have very few places to hide things on my buggy! plus I
can do away with the side stand relay...
