Author: Subject: wiring security - IVA
carlknight1982
posted on 31/1/11 at 05:05 PM Reply With Quote
Appologies is this is in the wrong section
Ive secured my wiring (all in ducting) down the trans tunnel with steel p clips but for the engine bay i want to use cable tie bases, am i right in assuming this is ok so long as the base is screwed/riveted to the chassis?
I dont want to do it then fail the IVA on it
Logic will get you from a A to B
Imagination will take you everywhere.
tomgregory2000
posted on 31/1/11 at 06:04 PM Reply With Quote
yep
adithorp
posted on 31/1/11 at 07:37 PM Reply With Quote
Yes, it'll pass (stuck on bases won't), but why drill extra holes in the chassis instead of just putting the tie around the tubes?
http://jpsc.org.uk/forum/
big-vee-twin
posted on 31/1/11 at 07:47 PM Reply With Quote
used P clips throughout
http://www.triangleltd.com
carlknight1982
posted on 31/1/11 at 07:52 PM Reply With Quote
I didnt think it would look real nice just tied to the chassis
and i didnt want to fork out for another 30 stainless p clips there working out dearer than the rest of the car!
britishtrident
posted on 31/1/11 at 09:01 PM Reply With Quote
Plastic P clips from B&Q
blakep82
posted on 31/1/11 at 09:06 PM Reply With Quote
yeah.... but you'll be using cable tie/tie wraps with the cable tie bases, so why not just cale tie round the chassis tubes?
________________________
