Author: Subject: Digi Dash Setup for a BEC
IainL
posted on 20/3/11 at 07:45 PM Reply With Quote
I've just wired up my ETB Digi Dash all seems to be working fine, but now I need to set the Alarms.
Therefore please could some one advise me what they would recommend the Alarms should be set at
The engine I'm running is a 919 Fireblade
Alarm
Oil Temperature
Oil Pressure
RPM/Oil Alarm
Shift RPM (max RPM)
Water temperature
Iain
MK9R
posted on 20/3/11 at 09:18 PM Reply With Quote
Oil Temperature - 130
Oil Pressure - 20
RPM/Oil Alarm - enabled over 2000rpm
Shift RPM (max RPM) - 11000
Water temperature - 110
As set up for the past few years on teh fury.
If its a digidash 1 i have all the config files which includes all the uk circuit splits etc.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
