<<  1    2  >>
Author: Subject: OMEX starting problems
perksy
posted on 29/3/11 at 07:58 PM Reply With Quote
Double check the crank sensor gap, Although if the ECU is seeing 150 rpm it can't be that far out (if at all)
Give the Loom/Connections a 'Wiggle' test just incase its a wiring/connection issue
a set of Noid lights would be a good investment and they're not that expensive tbh
Try reloading the Map file into the ECU, might sound daft but this has worked on a couple of Mbe's i've seen
also double check all the settings
There ain't that much it can be tbh apart from the Ecu and Omex have tested that
Not something Daft like the Injector pulse rates turned right down in the settings ?
Gold Leaf
posted on 14/6/12 at 11:21 AM Reply With Quote
Hello to all,
My apologies for pulling up this posting from last year, but I have EXACTLY the same problem as the one described by the chap who started the thread.
Are you still here Omega0684 ?
Can you please tell me how you resolved the problem in the end as my problem is exactly the same and I have been through the same checks etc as you.
Very many thanks
<<  1    2  >>
