Steve Hignett
posted on 18/5/11 at 05:08 PM |
Wanted:- Does anyone have a 380 Ohm Resistor please?
Hi All,
Does anyone have the above please, wanted quite urgently!
spiderman
posted on 18/5/11 at 05:20 PM |
quote: Originally posted by Steve Hignett
Hi All,
Hi Steve why a 380 ohm? As it is not a prefered value. Try a 370 ohm which is a prefered value and if you do definatley need 380 ohm use a 370+10 ohm
resistors in series.
These are available from Maplins, RS Components ect, they will probably want to supply them in packs which are quite cheap or buy a pack of mixed
value resistors. You will also need to know what current rating you need.
Spider
r1_pete
posted on 18/5/11 at 06:07 PM |
I can do you 360s and 10s, depending on what you want 360 is probably close enough......
liam.mccaffrey
posted on 18/5/11 at 06:10 PM |
variable pot? I'll have a look in the shed mate. Turn you phone on too!
Build Blog
Build Photo Album
Daddylonglegs
posted on 18/5/11 at 06:19 PM |
If you get stuck I'll have a look in my 'box-o-bits' BTW, what wattage do you need?
