Author: Subject: 2.1 pinto running problem
steve m
posted on 24/7/04 at 07:19 PM Reply With Quote
Hi
A work mate "Robin Hood Owner" is having major problems with his car
basic setup is 2.1 pinto, stage 3 head, twin 45's, standard ignition
the car has been used for 3-4 years and has all of a sudden developed a problem
The car will run very smoothly up to 4k
and with gentle throttle application will rev to 7k when the rev limiter will cut in
but on medium to hard throttle, the engine splutters, and will not run very well at all, and very flat
things we have changed
plugs, leads, dizzy cap,earth straps(they were dodgey) and coil
both carbs rebuilt and blown thru, but we have pretty well discounted a fuel problem
also overcharging is not the cause as per my posts on a very similar problem earlier this year,
regards
steve
macspeedy
posted on 24/7/04 at 07:59 PM Reply With Quote
couple of ideas
you didn't mention the timing, could be a fault in the dizzy, also is the compression good in all the cylinders.
jacko
posted on 25/7/04 at 08:22 AM Reply With Quote
pinto problems
Hi-Steve. .could there be a fuel filter in the pipe line which is partly blocked allowing fuel through when on low to medium throttle, but not enough for full throttle. Jacko.
theconrodkid
posted on 25/7/04 at 04:22 PM Reply With Quote
sounds like accelerator pump not werkin
who cares who wins
pass the pork pies
Mark Allanson
posted on 25/7/04 at 08:34 PM Reply With Quote
I had a Fiat 127 Sport with the same problems - it was a dead sparrow in the air intake pipe before the air filter!
Once the air demand exceeded the little corpse induced reduced capacity, the engine misbehaved. I replaced almost everything before I checked the stupid things
Sorry , no photo of the dead sparrow
